ldm1417
Sep 11, 2018Aspirant
[EX6150v2] cannot get connected to 5GHz band of router
Hi,
The extender cannot get connected to my router with 5GHz band.
Other devices do canget be connected to the router on this band.
How to solve?
Here is my current configuration:
router to...
ldm1417
Sep 13, 2018Aspirant
I've just got connected to the router 5GHz band with Galaxy S5.
Download speed: 86Mbps, Upload: 3.23Mbps (very similar as with wired connection), distance to the router: 0.5m
Sep 14, 2018Guru - Experienced User
Are you seeing an error when you try to connect the extender to the 5 Ghz router network?
If so, what error?
