alsarnotsky
Jul 17, 2018Aspirant
ex6150v2 client link LED is dark (Router link LED is green)
The client link LED is dark. (The routr link LED is Green). This worked properly for a long time.
I am trying to connect a 'samsung 'Tablet to a speaker via the extender.
I tried moving the t...
DexterJB
Jul 17, 2018NETGEAR Moderator
Hi alsarnotsky,
Welcome to the community!
1. What is the firmware version of the extender?
2. If the client LED is off, that means that there is no device connected to the extender's signal.
3. Is it a WiFi speaker? What model?
4. Is the tablet still able to detect to extender's signal?
5. Are you getting an error? If yes, what is the error?
Dexter
Community Team
DexterJB
Jul 18, 2018NETGEAR Moderator
Hi alsarnotsky,
Thank you for responding.
1. Do you have other wireless devices that can connect to the extender?
2. I believe your tablet is connecting to the speaker via Bluetooth and not via WiFi.
Dexter
Community Team
- alsarnotskyJul 18, 2018Aspirant
I just tried my LG smartphone and the phone did not find the extender as a source with which to connect. I have not tried other devices. I think the only other device I have is my wife's cell phone. So, at this time neither my cell phone nor my wife's tablet can connect to the extender.
You are correct the tablet is connecting to the speaker via Bluetooth and not via WiFi..
- DexterJBJul 18, 2018NETGEAR Moderator
Hi alsarnotsky,
If that is the case, you may want to consider resetting the extender and go through the setup process to make sure that it has been properly configured to connect to your main wireless network. Page 41 of the user manual on this link may help for the reset. This link for the installation guide may also be helpful.
Dexter
Community Team
- DexterJBJul 23, 2018NETGEAR Moderator
Hi alsarnotsky,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team- alsarnotskyJul 23, 2018Aspirant
I unplugged the extender and replugged it.
Now everthing seems to be OK
