Sepulchre
Feb 18, 2018Tutor
EX6150v2 DHCP Reservation
Hi, I have the D7000 and extend the network using an EX6150v2. My CCTV cameras connect to the extender and I then monitor from my PC and the TV in my lounge. The challenge I face is the IP ad...
DarrenM
Feb 28, 2018Sr. NETGEAR Moderator
Have you tried to reserve the cameras with the virtual mac or with the correct mac address?
DarrenM
Sepulchre
Mar 02, 2018Tutor
neither so far, as the cameras are not easy to access to reset should I not be able to access them. So I'm looking for advice before I try anything
- jvasanth1984Mar 21, 2018Virtuoso
Hi Sepulchre,
You must reserve the virtual MAC address of your cameras, but not the actual MAC address. You can look for it under connected devices of extender after connecting cameras to extender.
- SepulchreMar 22, 2018Tutor
Thanks, but I'm coinfused to how this would work as all deviced connected to the EX6150 appear on the D7000 with the same virtual MAC address
- jvasanth1984Mar 22, 2018Virtuoso
Hi Sepulchre,
Only the first part will be same. If you check last 6 characters, it'll be different for each devices.
