Sepulchre
Feb 18, 2018Tutor
EX6150v2 DHCP Reservation
Hi, I have the D7000 and extend the network using an EX6150v2. My CCTV cameras connect to the extender and I then monitor from my PC and the TV in my lounge. The challenge I face is the IP ad...
Sepulchre
Mar 22, 2018Tutor
I checked and the vurtual Mac address is the same for all cameras.
I have an ipad and a PC also being given the same Mac address, although different from the cameras.
All 12 digits checked
Sepulchre
Mar 22, 2018Tutor
| 92.168.0.27 | cam | XX:XX:XX:E2:79:11 | |
| 192.168.0.8 | cam | XX:XX:XX:E2:79:11 | |
| 192.168.0.28 | device2 | XX:XX:XX:E2:79:13 | |
| 192.168.0.13 | device3 | XX:XX:XX:E2:79:13 | |
| 192.168.0.17 | cam | XX:XX:XX:E2:79:13 | |
| 192.168.0.6 | cam | XX:XX:XX:E2:79:11 | |
| 192.168.0.28 | cam | XX:XX:XX:E2:79:11 | |
| 192.168.0.26 | printer | XX:XX:XX:E2:79:11 | |
| 192.168.0.9 | cam | XX:XX:XX:E2:79:11 |
Device names changes, real MAC addresses removed and virtual mac addresses modified on first 6 characters.
- jvasanth1984Mar 22, 2018Virtuoso
Hi Sepulchre,
This looks awkward. Do you experince the same issue for devices connected directly to D7000 but not via extender?
- SepulchreMar 24, 2018Tutor
no, devices coonected directly to the D700 show with their MAC addresses correctly and I can reserve IP's for these
- jvasanth1984Mar 24, 2018Virtuoso
Hi Sepulchre,
What firmware version are you running on extender now? Look for upgrade if any and see if that helps. If persist, I would recommend you to reset and reconfigure the extender and check.
- SepulchreMar 26, 2018Tutor
I'm runing the latest version - V1.0.1.70
I've reset and reconfigured but get the same result :(
- SepulchreMar 31, 2018Tutor
I'm getting no where with this...
the two virtual mac addresses given to all devices are those of the 2G and 5G networks, so there is no way I can reserve an IP given the same mac address is shared, this is really frustrating!
looks like i'm not the only one seeing this -
must be a 'feature'
