Sepulchre
Feb 18, 2018Tutor
EX6150v2 DHCP Reservation
Hi, I have the D7000 and extend the network using an EX6150v2. My CCTV cameras connect to the extender and I then monitor from my PC and the TV in my lounge. The challenge I face is the IP ad...
jvasanth1984
Mar 24, 2018Virtuoso
Hi Sepulchre,
What firmware version are you running on extender now? Look for upgrade if any and see if that helps. If persist, I would recommend you to reset and reconfigure the extender and check.
Sepulchre
Mar 26, 2018Tutor
I'm runing the latest version - V1.0.1.70
I've reset and reconfigured but get the same result :(
- SepulchreMar 31, 2018Tutor
I'm getting no where with this...
the two virtual mac addresses given to all devices are those of the 2G and 5G networks, so there is no way I can reserve an IP given the same mac address is shared, this is really frustrating!
looks like i'm not the only one seeing this -
must be a 'feature'
