debax
May 23, 2023Aspirant
EX6150v2 dropping 5G network after power reset
I have a Netgear AC1200 WiFi Range Extender, Model EX6150v2. It's directly connected to my Xfinity router via an Ethernet cable and is set up in Access Point Mode. The 6150 is located in a separate...
May 23, 2023Guru - Experienced User
You could always try reinstalling the firmware to it and doing a factory reset. Maybe something is corrupt in the firmware or the settings. That'd cover both of those options.
If that doesn't help, it might be time for a replacement. 5 years is a pretty good life span
debax
Is there a particular firmware version I should be using (or avoiding)?
- plemansMay 24, 2023Guru - Experienced User
I haven't really heard any issues with the extenders firmware on that version. But sometimes things happen and can get corrupt. Its worth a chance trying to reinstall the firmware.
