peterfrye's avatar
peterfrye
EX6150v2 has foreign firmware, should get original firmware
The extender was in use for Freifunk, where there completly different firmware is in use. I would like to restore the unit to the original firmware, otherwise it's waste. I have nothing that tells me how to do it with WINDOWS 10 Vers.20H2  on the PC.
any hints are welcome
    • peterfrye's avatar
      peterfrye
      Thanks for your reply.
      There is no REGION to set up in the current firmware, since it is for a creating a VPN-Network to get arronud rules of the german coverment. The task now is how to get the NETGEAR-firmware onto the unit.
      • plemans's avatar
        VPN's typically don't go on extenders. They go on the router or on the pc being used.
        not sure exactly what you're attempting or trying to do because your descriptions are pretty vague.
        Also, the extenders do have regions. its under setup--->wireless setup---->region selection
