captainturk
Aug 28, 2025Aspirant
EX6150v2 resetting to factory defaults
My EX6150v2 is resetting itself to factory defaults. I'm guessing after a powerful outage, but unsure. It's configured for access point and type ethernet running firmware 1.0.1.108. But when it arbi...
CrimpOn
Aug 28, 2025Guru - Experienced User
captainturk wrote:it fails open
Please explain what "fails open" means.
captainturk
Aug 29, 2025Aspirant
CrimpOn, for example, a firewall configured to fail closed will block all traffic if it crashes, preventing unauthorized access during the failure. In physical security, a courthouse metal detector failing closed means no one gets through until it's fixed.
When the EX6150v2 reverts back to factory defaults on its own, it should prevent unauthorized access and fail closed as opposed to failing open and allowing anyone within range to access my network (i.e. open Wi-Fi with no encryption.)
