paulfoot007
Feb 18, 2018Aspirant
EX6150v2 WiFi Extender - connected but no internet
Hi: Purchased this recently and have had issue with connecting to the wifi ap on my cable modem. Initially ipads, phones, laptops connected OK but now I have to powecycle the extender multiple times...
paulfoot007
Feb 26, 2018Aspirant
Thanks. Tried all that and it didn't help at all. Just resetting modem and extender every day, which is unacceptable.
DarrenM
Feb 28, 2018Sr. NETGEAR Moderator
Hello paulfoot007
Have you tried to re position the extender to a different location?
DarrenM
- paulfoot007Jun 29, 2018Aspirant
Yes
- DravoJul 22, 2018Tutor
Have you found a fix I have to reset everyday as well
- paulfoot007Jul 23, 2018Aspirant
No I haven't yet, It appears to be some sort of DHCP conflict, I notice my laptop gets a 169.x.x.x address which is a default when you don't have an IP. Also, it is possible there is an issue with a MAC table not flushing correctly. I am going to try changing configuration on the gateway to extend the lease time to 24 hours and try to statically assign IP outside of the pool. Pretty frustrating.
