njmckenzie
Sep 16, 2015Aspirant
EX6200 - Stops assigning IP Addresses
Just purchased the EX6200 wifi extender two weeks ago and the setup went fine and network performance (speed/latency) was good. Recently, I am needing to reboot once a day in order for devices to be ...
- Sep 28, 2015
Three days with no reboots required and counting (fingers crossed it continues). So it does appear to be the main router's configuration that was somehow messing with the EX6200. The previous factory reset was actually not a complete reset (operator error and it only reset some of the settings) but this one was complete and effective so far at ensuring the laptops / printers stay connected. This also helped isolate a different problem on the phone to a particular wifi prioritization app that was causing the dropoff of wifi.
njmckenzie
Sep 17, 2015Aspirant
One more update. Yesterday the lease time at 2 minutes seemed to be working although today at roughly one day since resetting the router, the network was lost again requiring ex6200 reboot.
nhann
Sep 18, 2015NETGEAR Employee Retired
Hi njmckenzie,
When you changed the lease time for the IP, are you also experiencing the issue when connected to just the router?
From the description you provided, it doesn't sound like it is an issue with the EX6200.
Please try to reset your Technicolor to factory defaults.
- njmckenzieSep 21, 2015Aspirant
nhann - I am not experiencing any issues when connected to the main router (either wirelessly or wired). I am going to try factory reset on both the router and the extender and basically start from scratch. This morning, four reboots of the EX6200 have been done and each time, it will recognize some of the wired connections but not all, and none of the wireless connections.
- nhannSep 22, 2015NETGEAR Employee Retired
Okay, great.
Let us know how it works for you
- njmckenzieSep 24, 2015Aspirant
The factory resets did not work and I am experiencing the same issues again.
