Beck1948's avatar
Beck1948
EX6200 Authentication Error comes and goes
This unit has worked fine on a fairly long repeater link, through many walls, of course best at 2.4ghz, without using fastlane and also using the main router password; only one roku device at the far end so easily streams 4k with no problems. However, the first 3+ years it rarely 'lost' the ability to connect to that main router, the roku failed to maintain connection, and my phone would also fail and give a 'authentication error occured' message. The 2.4ghz out of the main router connected fine, but again this happened maybe twice a year. Recently its started happening every couple of weeks; I do note the recieve LEDs are sometimes dropping from green to amber, but not when my phone connection drops or the roku stalls.
It is possible that over the years the RF from the main wifi unit has dropped, and I put in a new external antenna on the ex6200 to try and get the status LEDs to be solid green, and I have another antenna solution to try but, I don't understand how most the time the roku keeps running while my $1500 galaxy phone reports these 'authentication errors'.
Wish the ex6200 would report actual recieved signal levels, but no. I see lots of folks get these errors but I don't see any solutions.
  • Would be nice if this blog allowed a way to add comments but I guess not.
    I went back and reviewed all the manuals for this device, and the one thing that stood out was that if one wanted to use it in pure repeater mode, sans fastlane i.e. 2.4g to 2.4g with 5g to 5g, there wasn't a way to set up those individual freqs from ones main router, the setup only allows one ssid as an input not two. So I naturally chose the 5g output from my main router, and tested that the extender did allow both 2.4g and 5g outputs to be attached to. And this worked fine for over some 3 years to a 2.4g device (a roku that was some 30ft and two walls away). I may have had 1 or 2 drops but maybe not even that, biggest actual crash was when the roku power cord got caught up by a vacuum cleaner which ripped out the hdmi cable and pulled the roku off the tv cart and destroyed it to the point I had to replace it.
    Then I had my home siding and windows replaced with dual panes and where I had the extender in a window no longer quite worked, so I had to move it. That's when things got shaky, the link rate leds for 5ghz would sometimes go to amber and every couple weeks the roku and my phone would not connect to the extender, I'd get the 'authentication error' on my phone; the roku would basically sit there and play dumb. I put a long range antenna on one of the extender ports pointed at the base router, didnt seem to help the occasional amber, but the unit is now two walls away from the main. In using my phone to do some RF sniffing I can extend a different antenna several feet eliminating one wall where my phone app says the 5ghz signal is at least 10-20+ db stronger. At the end of the day I might give that a try but the s/w setup is in my opinion a bit wanky as it doesn't appear to allow two wifi connections at the same time (both bands) when manually setting up with the browser instead of the WPS. Maybe I'm wrong, I may just reset the thing to factory and go through it again, I just don't remember getting that option with the browser and things worked pretty much great at the time so didnt give it any thought.
    • Beck1948's avatar
      Beck1948
      Extended one of the antenna ports /w antenna to within 30' of the main wifi router, one dual pane window away, where signal level exceeds -55dbm on 5ghz. Yet ex6200 repeater still wobbles between green and amber on the 5ghz receiver level display on the front of the device. When I retested it a couple weeks ago some 20' away from the main in another room but only a hallway between, it appeared to be solid green. I can move the extended antenna closer to that testing point with no walls/windows but will take another day, my ladder climbing is at a minimum.
      • Beck1948's avatar
        Beck1948
        The question of the day: the unit has two antenna ports . I assumed that both 2.4 and 5ghz are transmitted/recieved by both as there is no reference in any manual saying different. I'm about to test that tomorrow, moving one of the ports and antennas into a point where its output is fairly shielded from the other antenna, around 20db. If it shows no increase (should be max with my RF meter right next to it) then either the unit is defective or the build/design is wacky with power and reception going mostly or all to the other antenna port.
