FYates's avatar
FYates
Ex6200 cannot access ReadyShare drive in Ubuntu Mate 16.04, works fine Windows 7
My EX6200 works fine on all the Windows computer, but cannot access the \\Readyshare drive using Ububtu Mate 16.04. The Ubutu compter connects to the WiFi through the EX6200.
This screen shot shows the problem. Hopeing someone has a clue. Thanks, Fred
  • FYates's avatar
    FYates
    Feb 08, 2018
    A User on Stack Exchange pointed out 192.168.0.14 was my laptop address, not the EX6200 address like I thought.
    I found the address for the EX6200 by logging on to my router and looking at the Device table. Using the correct address in the "Connect Server" popup solved the problem.
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi FYates,
    1. Is the ReadySHARE drive connected to the EX6200 or to a main NETGEAR router?
    2. Does the issue persist if the Ubuntu computer is connected wired to the EX6200?
    3. Can the Ubuntu computer ping the router and/or the extender?
    4. Can the Ubuntu computer access the ReadySHARE drive via http and/or ftp?
    5. What is the firmware version of the extender?
    Dexter
    Community Team
    • FYates's avatar
      FYates
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi FYates,
      Thank you for the update and confirmation. Glad to know you got it working.
      Dexter
      Community Team
