Kira_J
Jan 31, 2018Follower
EX6200 cannot add 5 GHz band
I have had this extender since 2015 and had no problem with it until I recently changed my service provider (from Comcast to Sonic Fiber), which prompted a need to re-connect the extender to the new router. However this time around it won't connect to the 5 GHz band (using the WPS buttons). I had no problem connecting both before, but now the extender only has the 2.4 GHz light on. I checked on the router admin page which confirms that both 2.4 and 5 GHz WPS are enabled so I assume it is the problem with the extender (or compatibility issue?).
Any suggestions will be appreciated! It is driving me crazy!
1 Reply
- DarrenMSr. NETGEAR Moderator
Did you do a factory reset when setting the extender up? to factory reset hold the reset button for 10+ seconds.
DarrenM
