HC1Gunner
Aug 08, 2014Follower
EX6200 Can't Connect ? ? ?
What really ticks me off is...I can login into my router all-day long using its IP address, but I have never been able to login to the Extender using its IP (192.168.1.250), nor does mywifiext.net wor...
storm_2003
Aug 19, 2014Novice
Just make sure that you have enough signal from your router where the extender is located then it should just work fine. Check the LED indicators or your Laptop's signal strength to identify if it is weak or strong.
Solid green. Best connection
Solid amber. Good connection
Solid red. Poor connection
Off. No connection
Off. No connection
