EarlThorfinn
Dec 23, 2015Follower
EX6200 connection issues with the firmware version V1.0.3.68_1.1.104
My EX6200 is set up in AP mode, connected to a Fritzbox by a 1GB wired connection. After upgrading to the latest firmware, my Surface Pro 3 would not connect to either the 2 MHz or 5MHz bands. My And...
DarrenM
Dec 28, 2015Sr. NETGEAR Moderator
Hello Earlthorfinn
Thank you for the feedback about the surface pro 3 and we are sorry this issue happened as we cant test every device on the market but I will pass this to the engineers about this device.
DarrenM
- page_faultJan 23, 2016Tutor
The latest firmware for this is a nightmare, do not install it. It seems like they didn't test anything the speed and the range makes it a useless product. Stick with 1.0.1 until they fix it.
- aholland1Jan 30, 2016Aspirant
I can also confirm this issue with a Surface Pro 3, running Windows 10 Build 10586.71, driver version 15.68.9037.59 for the Marvell AVASTAR Wireless-AC Network Controller which just rolled out in the last week or so. I updated my AC1200 to this most recent firmware 1.0.3.68_1.1.104 and still the issue persists.
My unit is configured in FastLane mode to broadcast 5Ghz only to devices and use 2.4Ghz as the backhaul to the router. I've changed the setting under Device Manager -> Properties for Marvell AVASTAR Controller -> Advanced Tab -> Band -> 5Ghz Only and confirmed I can successfully connect to the other 5Ghz network coming off my primary AP. However upon attempting to connect to the AC1200 Extender I only get Limited/No Connectivity. I'm prompted for my password (WPA 2 Personal) and it appears to be connecting, but eventually times out and says No Internet.
Other devices including my new 5Ghz Chromecast and Moto Droid Turbo 2 can connect to the AC1200 Extender with no issues on 5Ghz. To me, this appears to be a driver compatibility issue with the Surface Pro 3 and AC1200 that has not been fully tested.
For what it's worth, I was having this same issue on the last version of firmware as well (both for the AC network adapter, and the AC1200 - issue persisted after surface was updated, then after AC1200 was updated).
Any suggestions I could try on my end to resolve? Thanks for your feedback!
- Dacow79Mar 10, 2016Aspirant
I only bothered looking at this issue today and I should have known it was the firmware that caused it after all the other issues I had with Netgear products and firmware!
Just in case anyone stumbles across this, to downgrade the firmware just go to this URL: http://kb.netgear.com/app/answers/detail/a_id/27192/related/1
