EarlThorfinn
Dec 23, 2015Follower
EX6200 connection issues with the firmware version V1.0.3.68_1.1.104
My EX6200 is set up in AP mode, connected to a Fritzbox by a 1GB wired connection. After upgrading to the latest firmware, my Surface Pro 3 would not connect to either the 2 MHz or 5MHz bands. My And...
Gregmh
Mar 14, 2016Aspirant
I to have this issue with the new firmware on my ex6200. With the new firmware I had trouble with the 2.7 mhz connection with it having restricted function and slow operation like excessive traffic. The wps would fail due to time out. The 5mhz worked fine. After loading old firmware all worked fine. This problem has been known for a while now, there is a old post on this problem which has been closed unsolved.
- GregmhMar 27, 2016Aspirant
To add to this I have down graded this to software v1. 0.1.60_1.1.98. This is working better but I have to restart it every day as it bogs down and get a lot of time outs. As mine is under warranty I will be lodging a claim. Does anybody else have a solution. Really I'm thinking of throwing it in the bin and buying a different brand.
