jerrychen_cn
Oct 28, 2015Guide
EX6200 connection issues with the firmware version V1.0.3.68_1.1.104
I have an ex6200 running in AP mode connecting with a R8000(nighthawk). Before I updated it to the firmware version v1.0.3.68_1.1.104, it had worked very well. I means it was steady and i was able to...
- Oct 31, 2015
OK, well it may be worthwhile trying the previous firmware version again.
Babylon5
Oct 29, 2015NETGEAR Employee Retired
Have you tried different wireless encryption methods, excluding WEP / TKIP? If you temporarily disable encryption do you still connect at a lower rate?
jerrychen_cn
Oct 29, 2015Guide
After I reset it, i have attempted to connect to it by default SSID NETGEAR_EXT5G or NETGEAR_EXT without any encryption. But the connection speed is the same.
- Babylon5Oct 31, 2015NETGEAR Employee Retired
When you say that you reset the extender, do you mean a factory reset? If not then that may be worth a try. Otherwise, you could try reverting to your previous version of firmware, you simply upload it manually and ignore any warnings that it is older than the current firmware.
- jerrychen_cnOct 31, 2015GuideYes. I have tried factory reset two times by Web UI and pushing reset button respectively.
