jerrychen_cn
Oct 28, 2015Guide
EX6200 connection issues with the firmware version V1.0.3.68_1.1.104
I have an ex6200 running in AP mode connecting with a R8000(nighthawk). Before I updated it to the firmware version v1.0.3.68_1.1.104, it had worked very well. I means it was steady and i was able to...
- Oct 31, 2015
OK, well it may be worthwhile trying the previous firmware version again.
jerrychen_cn
Oct 31, 2015Guide
Yes. I have tried factory reset two times by Web UI and pushing reset button respectively.
Babylon5
Oct 31, 2015NETGEAR Employee Retired
- jerrychen_cnOct 31, 2015GuideThank you for your suggestion. An hour ago, i did a downgrade on firmware from this version to V1.0.1.60_1.1.98. Now, it is back to normal.
- Babylon5Oct 31, 2015NETGEAR Employee Retired
Thanks for the update, I’m not aware of any other similar issues with the new firmware, but I will bear this in mind.
- emmepiNov 04, 2015Aspirant
I've experienced many issues with this upgrade:
- no more connection with hp photosmart printer
- many problems in connection with chromecast
- connection stability worst than before.
I downgraded and now all works fine.
- APVNov 21, 2015Aspirant
how did you do thw downgrade?
thanks,
APV
- jerrychen_cnNov 21, 2015Guide
Here is the download link:
http://www.downloads.netgear.com/files/GDC/EX6200/EX6200-V1.0.1.60_1.1.98_FW.zip.
And then, you need to login the web admin page to upload it and ignore the fireware version alert, which just likes the upgrading.
