nickambrose
Aug 16, 2015Tutor
EX6200 drops 2.4GHZ connection every day or so
For some reason my EX6200 drops the 2.4GHZ connection every day or so. The 5GHZ is fine and both my 2.4 and 5GHZ connections on the router are fine. Rebooting fixes the issue for another day or s...
MarkNC
Nov 05, 2015Aspirant
Same problem here. Right out of the box. I had to switch AT&T unite pro modem to 2.5GHZ only as some devices in house do not work on 5GHZ.
nhann
Nov 06, 2015NETGEAR Employee Retired
Hi MarkNC,
Which firmware version is your EX6200 currently on?
Try updating to latest firmware:
http://support.netgear.com/product/EX6200
- MarkNCNov 06, 2015Aspirant
I did update to the latest firmware when installing a few days ago. Also checked it again just now through the genie. Still having same problem. I have to just shut off the 5ghz and run with the 2.5.
- gmhymanDec 07, 2015Guide
My EX6200 has been replaced twice (!) under warranty - the first one was essentially dead, now the second is having this same problem as others - drops the 2.4 gHZ connection every day or so. If I don't reboot in time, eventually the 5gHz connection drops as well. I'm using a static IP, and am on the latest firmware. It's becoming obvius that this model has substandard something - hardware, firmware or both. A real stable solution would be most appreciated.
BTW - my 2 most recent support tickets were declined because it's a warrany box and therefore out of warranty for software issues - in other words, Netgear doesn't give a d**n about me as a customer, and probably not any other customer either!
- nhannDec 07, 2015NETGEAR Employee Retired
Hi gmhyman,
Please connect to your EX6200 via an ethernet cord. Login to mywifiext.net and upload the previous firmware version v1.0.1.60_1.1.98
http://downloadcenter.netgear.com/en/product/EX6200#searchResultsOnce you download the firmware zip file, unzip the chk file and upload it to the EX6200. See the user manual page 81 of 124:
http://www.downloads.netgear.com/files/GDC/EX6200/EX6200_UM_09Jan2015.pdf
