nickambrose
Aug 16, 2015Tutor
EX6200 drops 2.4GHZ connection every day or so
For some reason my EX6200 drops the 2.4GHZ connection every day or so. The 5GHZ is fine and both my 2.4 and 5GHZ connections on the router are fine. Rebooting fixes the issue for another day or s...
Babylon5
Aug 18, 2015NETGEAR Employee Retired
Nick, Metzger, DigitalMaestro (thanks for the link),
I will raise this with Netgear to see if this is a recognised issue.
Did this issue appear immediately after first setup, or some time later? If later does a factory reset resolve the issue for a while?
DigitalMaestro
Aug 19, 2015Star
Babylon5 wrote:
Nick, Metzger, DigitalMaestro (thanks for the link), I will raise this with Netgear to see if this is a recognised issue. Did this issue appear immediately after first setup, or some time later? If later does a factory reset resolve the issue for a while?
I can't speak for others but the issue occurred for me right out of the box and was not affected by a factory reset. Netgear eventually also did a hardware swap and that also did not resolve the problem. Since the same symptoms were exhibited by the replacement unit provided by Netgear then it points to a firmware issue to my mind. Netgear did provide one or two beta firmware releases for me to try but none resolved the issue.
DM
