Beck38
May 10, 2016Aspirant
EX6200 'Fastlane' Poor Throughput
New EX6200 w/ f/w upgraded out of the box to 1.0.3.68.1.1.104. Unit was extensively tested in 'standard' mode, repeatering on both 2.4 and 5Ghz; throughput was ok with some small decrease from th...
Doug_Ho
May 13, 2016Apprentice
I believe the firmware which worked best full-speed FastLane for me the last half-year (have not tested the one from this week) is EX6200-V1.0.1.60_1.1.98_FW. I do not recall what special steps I may have done to "downgrade" (they may be something like reset-to-defaults, then downgrade, then reset-to-defaults again, then go through the setup).
Beck38
May 13, 2016Aspirant
I'll take a look at what it will take to do that, maybe I'll take the plunge and try the latest as well just for kicks, since although I may 'brick' the unit once again, I'm still well in the 30 days return from Amazon Prime.
