KiccoLSD
Oct 29, 2015Guide
EX6200 FW:V1.0.3.68_1.1.104 AES encryption setting bug
I’m using the EX6200 as AP with the latest firmware and I’m experiencing a strange issue: Both my Macs (One IMac 09 and one MacMini12 both with OS X 10.11.1) report “a” protocol link with 5Ghz and “g...
TheEther
Oct 29, 2015Guru
Do you have any old devices that can only do 802.11g?
It's very strange to see a Mac using 802.11g. Can you try enabling 20/40 MHz coexistence on the extender? I have a feeling that it could be causing the extender to not behave well.
The RSSI at 5 GHz is terrible. It's barely above the noise level. Are Wi-Fi channels 100 and higher available in your region? The lower channels generally have low transmit power. At the very least, try to change to a different channel. Channel 60 could be congested.
