KiccoLSD
Oct 29, 2015Guide
EX6200 FW:V1.0.3.68_1.1.104 AES encryption setting bug
I’m using the EX6200 as AP with the latest firmware and I’m experiencing a strange issue: Both my Macs (One IMac 09 and one MacMini12 both with OS X 10.11.1) report “a” protocol link with 5Ghz and “g...
KiccoLSD
Oct 29, 2015Guide
No g/a devices. If i set tkip+aes the both macs shift to n thanks to aes encryption. 20/40 was enabled then i tried to see if behave better without.
The 5ghz rssi now is 61db with 50% power transmit. The strange thing is that in the gui i cannot select channels over 46, I cannot figure out how channel 60 was selected. Btw rssi now is good also because while taking the screen the old 5ghz wlan was active and in the same channel.
