Repo16
Jan 17, 2016Aspirant
EX6200 lights flashing and 5g light does not light up
I have a new extender and the lights always seem to flash, not sure if it's not in a good spot in the house? When I set it up I could not get the 5g light to light up.
Repo16
Feb 04, 2016Aspirant
Thanks I will try tomorrow
Repo16
I was able to get the 5G to work now
However.....it still goes off line and the lights flash
- doraemonFeb 04, 2016Prodigy
How did you get it to work?
How's the connection on 2.4GHz?
Try to set it up near the router to tell if it's the location or what.
Interference on 5GHz is very rare but see to it that there's no other wireless device that may cause it.
- Repo16Feb 09, 2016Aspirant
I hooked it up directly to the computer and changed a setting. both setting work well now.
However it still goes off line and flashes i'm wondering if it is to far from the router.
thanks
