mlevin77
May 28, 2015Tutor
EX6200 suddenly not making network; only up/down green arrow lights on
I have a Netgear EX6200 wifi range extender. It was working fine for a couple of months (extending a network from a Netgear router on the 1st floor), but suddenly our devices cannot see its extended ...
mlevin77
Jun 01, 2015Tutor
Babylon5 wrote: I would recommend that you note down all settings then factory reset after the firmware upgrade, and then re-enter settings manually.
is this better than restoring a config file? What's the downside of the config file method?
