Jshoe
Oct 31, 2021Tutor
Ex6200 vs Eax20- Do they actually work differently?
I've had an EX6200 for years with a separate SSID for my network. Im going to switch that to the same SSID of the network. Then I can't easily switch between the the extender and the router. How does the EAX20 solve this issue? It supposedly turns the network into a mesh network. Can someone give me the technical breakdown of how the technology works? It seems as though it's more of a marketing ploy. How does the device know which node to connect to and roam to the next? The EX6200 has this drawback because it holds onto the connection even if weak. Thanks
The EAX20 doesnt control the roaming.
Newer devices all have their own roaming protocol built in to where they should roaming to the stronger AP based on the details the AP sends to it. .
Not always stronger based on certain criteria but thats the basics of it.
so the EAX20 uses the same ssid but has the smart roaming spec built into it. so when a device queries it, it can respond to let the phone/tablet know its details so the phone/tablet can choose which network to content to.
That's a very very broke down way of explaining it.
If you want to get more into details, feel free to read here:
https://www.smallnetbuilder.com/wireless/wireless-features/33195-wi-fi-roaming-secrets-revealed
- JshoeTutorSo it doesn't do anything different and I have no gain by buying it for mesh networking? In mesh networks I have setup in the past the device hops from AP to AP no issue. This is on an 802.11AC network using the same devices. With my EX6200 my devices stay connected to said EX6200 even if the router has a stronger signal. How is the EAX20 going to fix this for me?
Didn't necessarily say the EAX20 would fix that.
The problem is both the router and the device you're using.
If the router doesn't have the proper roaming protocols, the device won't switch until the signal is quite obviously different/unusable.
If the device itself doesn't have the roaming protocols, then you're in the same situation.
Mesh networks are great but they aren't quite as efficient when its using pieced together setups like adding extenders.
If you're truly wanting to go mesh, look into the orbi or MK nighthawk setups where the whole system works together
