swegeman's avatar
Jul 11, 2017
EX6200 WiFi Extender connected to mobile MiFi with limit of 10 connections but need more!
Hi i have a Ac1200 EX6200 WiFi Extender connected to a mobile MiFi for home internet with unlimited Data.
Problem is this new Mifi is limited to 10 connections. Even when I have everyone connected thru the extender is show on the MiFi as connections. When you start adding up the connections (Amazon Echo, Ring doorbell, 3 smart TV's, 2 BluRay Players, 3 desktop computers, 2 laptops, 4 cell phones, 3 iPads) These add up to 19 connections. I then have to stat going around the house and turning off wifi devices.
Question is how can I add more connections by using the Extender or another device so they show up as a single connection on  MiFi?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello swegeman
    I know sometimes if you use a switch all the connections do not show up or you may want to try and bridge the Mifi and use another router but that would require some sort of router that requires usb connection or being able to hook ethernet into the mifi.
    DarrenM
