DeeBeeEff's avatar
DeeBeeEff
EX6200V2 as Access Point won't connect 5ghz through ethernet; still shows connected through router
Hi. I searched this before I posted but couldn't find a relevant answer. I just switched my EX6200 to AP mode on my ethernet. Everything on the 2.4ghz network is working fine.  On the 5ghz, it ...
  • DexterJB's avatar
    DexterJB
    Aug 01, 2018
    Hi DeeBeeEff,
    The 5GHz connection that you are referring on the screenshot is the extender to device connection. That means that you currently do not have any wireless device/s connected to the 5GHz band of the extender. That should change once you have a device connected to the 5GHz band of the extender.
    Dexter
    Community Team
