ixncxlxkxxth
Jan 26, 2019Aspirant
Ex6200v2 Ethernet droping connection every 20-30 minutes
Ive been having problems with m Ex6200v2 where ive been using for ethernet on my gaming pc and when i play any game about 15-30 minutes into something it just disconnects me for about 15-20 seconds a...
ixncxlxkxxth
My router/modem is a arris TG2472
Christian_R
Jan 31, 2019NETGEAR Employee Retired
Hello ixncxlxkxxth - Have you tried connecting another device wired into the extender to see if the behavior is the same?
~Christian
- ixncxlxkxxthJan 31, 2019AspirantSo ive had a laptop hooked up to it but i only notice it when im playing games like rainbow six siege, rust, and grand theft auto and my laptop cant play games like that
- Christian_RJan 31, 2019NETGEAR Employee Retired
ixncxlxkxxth - When you connect the laptop directly to the router, does the same issue occur?
~Christian
the laptop doesn't drop connection its my pc that is custom built into my desk is and my router is in another room. Sometimes with the xbox when it is on ethernet it drops connection to the ex6200v2.Ive used the ethernet port on the mobo and i got a pice network card and it still drops s oi dont believe its hardware based
Hi ixncxlxkxxth,
A couple things:
1. You could try reserving the IP address of your pc on the router so it does not try to assign it a new one every time it is turned on
2. What is the status of the router link LED when it drops?
3. Have you tried switching out the cable that is connected to the extender and pc?
~Christian
- ixncxlxkxxthJan 31, 2019Aspirant1. How would indo that ive got no clue
2 all the lights on the router stya connected im pretty sure but i cant move that fast to see the lights when it times out
3. Ive tried at least 15 different cables
