adamgusky
Jun 10, 2021Aspirant
EX6250 — AC1750 Dual Band WiFi Mesh Extender -> DL speed of 0. Upload speed of 1.01.
Hi, I am extremely dissapointed with Netgear. I bought the AC1750 around November of 2020 because I work from home in a remote part of the house, far from the router. My video meetings were ...
adamgusky
plemans hi and thanks for the reply.
1. Router: RAC2V1K
2. Firmware: V1.0.0.134
3. Yes I have tried multiple locations. near the router, in between the router and my office, and near my office
4. Would this be the network map? If so there are green dots by the EX6250 and by the router, but there is nothing by the Internet
Jun 10, 2021Guru - Experienced User
I've seen constant install issues with that router. And not just from netgear.
Re: EX3700 connected but no internet - NETGEAR Communities
Issues using a TP-Link Range Extender with Spectrum Internet services - Home Network Community
Need a wifi extender compatible with RAC2V1K — Welcome to the Spectrum Community
- adamguskyJun 10, 2021Aspirant
I don't think it is the router, because it worked with my previous EX6250 until it broke and they sent me a new one. Am I thinking about this incorrectly?
- plemansJun 10, 2021Guru - Experienced User
Try installing using the installation assistant. If that doesn't help, then try the WPS method.
Sometimes one works better than the other.
You might also try setting a static ip address
