Bendeego
Feb 06, 2019Guide
Ex700 Ethernet connection problem
My smart tv will not connect to the EX7000 via Ethernet cable ,but it will connect via Ethernet cable to my EX6200,,,
i am unable to determine if there is a difference in Ethernet protocol
the EX...
Bendeego
Feb 18, 2019Guide
Hello ,sorry for the delay in answering,,
no the tv does not show in the connected devices in the ex7000,,
the tv works fine with the 6200 ,and it shows in the connected devices,,
,I thought the ex7000 was auto sensing,,,The Lg tv only handles 10/100 ,,
regards
PeterH
Bendeego
Feb 21, 2019Guide
Hi,I believe I have solved my problem of not being able to connect my ex7000 to my LG tv,,via Ethernet ,,I changed my connection to Static ip,,and also smart connect and low and behold it now works ,,,doesn’t explain why my ex6200 works with DCHP ip addresses and the 7000 doesn’t ,,,,hope this helps someone,,,oh and I changed security settings also,,,
cheers
