John_Casey
May 02, 2018Aspirant
EX7000 -Need Advise On Extending Network To Garage
I need suggestions on extending my WiFi. I am interested in purchasing the needed equipment to extend my current WiFi to my garage. The garage is in direct line of sight approximately 300-350 feet aw...
DarrenM
May 03, 2018Sr. NETGEAR Moderator
If you garage is on the same power circuit as you home you may want to look into power line adapters.
https://www.netgear.com/home/products/networking/powerline/default.aspx
DarrenM
John_Casey
May 03, 2018Aspirant
No unfortunately it has a separate service.
- DarrenMMay 03, 2018Sr. NETGEAR Moderator
Do you get a solid wifi signal in any part of the garage?
DarrenM
- John_CaseyMay 03, 2018Aspirant
No strong signal inside at all, it will connect but not stay connected.
- DarrenMMay 10, 2018Sr. NETGEAR Moderator
Not sure a extender will help because it needs good signal in order to cover another area unless you can put a extender at the edge of the house close to the garage and it can get a better signal.
DarrenM
