Tammyz
Oct 29, 2017Follower
EX7000 AC1900 range extende lost login and password
Need some advice on what to do with the above mentioned lost login and password. The only thing connnected to the extender was my television and unfortunately it has lost its connection.
Not sure if these can be retrieved.
Thank you for your help.
1 Reply
- DarrenMSr. NETGEAR Moderator
You can revert it by holding the reset button for 10 seconds then it will be admin/password
DarrenM
