Tarkus
Dec 29, 2018Tutor
EX7000 as WAP, sporadic service
My home has two EX7000s acting as wireless access points, both connected via gigabit ethernet to my home network. They are sited at two opposite corners of the property, close to two security cameras...
Dec 31, 2018Guru - Experienced User
One option is to download the trial version of pingplotter, and set up a ping test between a device on the extender network and a device on the router network. That will graph the responses, and let you see connectivity drops.
Tarkus
Jan 06, 2019Tutor
Ping tests show that the access point is online; the camera is not. I'm referring the problem to the camera supplier because I no longer think this is a problem with the WAP.
- PingPlotterJan 08, 2019Aspirant
Hey there!
I saw that you were trying to troubleshoot something using PingPlotter. I'm on the PingPlotter service team and I wanted to let you know that we have a new service out called Reader, in which we troubleshoot your connectivity issues for you and give you a detailed report on our findings. If you're interested, head here:
Hope to see you there!
Hayla
