Tazze
May 05, 2021Aspirant
Ex7000 doesn't connect to wifi anymore.
I have the AC1900 Wifi Range Extender EX7000 and my home had recently got the Orbi mesh extender or whatever. Though for some reason, after installing the Orbi mesh thing, my extender doesn't connect...
May 05, 2021Guru - Experienced User
you might be able to connect the extender to the orbi network but it won't integrate with it.
You'd want to install it using the installation assistant and I wouldn't use it as a mesh device. (give it a seperate ssid)
It doesn't have the dedicated backhaul the triband orbi's do.
So if you really want to add it try setting it up using the installation assistant and NOT wps.
Tazze
May 06, 2021Aspirant
How would I go on about doing this? Setting it up with the orbi and all?
- plemansMay 06, 2021Guru - Experienced User
You'd use the installation assistant and NOT wps.
- TazzeMay 07, 2021Aspirant
That doesn't work either, if I plug in my computer to the extender through an ethernet cable my computer says "Unidentified network". I have tried this with other computers in my house and got the same result, so it is definitely the extender. The 2.4 and 5 GHz LEDs still stay amber consistantly and never blink. There's also no wireless thing that pops up in the list of wifis.
