ngsksnet
Jan 02, 2019Follower
ex7000 doesn't work
at the last step, you have to connect to wifi before checking the last box. Problem, the extended signal is now strong, but connection is always limited. So it's uselessly strong. You can't connect t...
Jan 02, 2019Guru - Experienced User
ngsksnet wrote:
Even this post page doesn't work. there is a box to enter a model number, but you can't enter anything in there. Sheesh.
I'm not a fan of the model number entry, but if you had entered EX7 in that field you would have seen three models, the first one being the EX7000. I added the model for you.
I think it's best for Netgear to review (and hopefully respond) to the rest of the feedback in your post.
