ngsksnet
Jan 02, 2019Follower
ex7000 doesn't work
at the last step, you have to connect to wifi before checking the last box. Problem, the extended signal is now strong, but connection is always limited. So it's uselessly strong. You can't connect t...
Christian_R
Jan 04, 2019NETGEAR Employee Retired
Hello ngsksnet,
Thank you for your feedback as it helps us improve our products and quality of service. Have you referred to the following article to connect to mywifiext.net?
https://kb.netgear.com/29746/I-can-t-access-www-mywifiext-net-what-do-I-do
~Christian
