JackalopeTX
Sep 17, 2018Aspirant
EX7000 ethernet only bridge mode
I have an EX7000 range extender and I want to run it ONLY as a wifi bridge for my workstation computer with ethernet only. Current firmware. I'm connecting to community wifi from my apartment complex...
JackalopeTX
I'll try mywifiext.local instead of .net. I can't see the IP of the extender because it's community wifi so I don't have a way to see devices connected
JackalopeTX
Wait, I'm pretty sure I've tried the local URL before and it didn't work. It seems to be Mac only. Is it a known bug that prevents mywifiext from working? If there's no solution I might just return the EX7000 and try the Linksys RE9000 instead even though it's more expensive
- JackalopeTXSep 17, 2018Aspirant
Again, once connected to the community wifi, www.mywifiext.net is inaccessible and so is .local. I'm just going to exchange it for a Linksys
- StephenBSep 18, 2018Guru - Experienced User
.local isn't mac-only and should have worked with Windows. https://kb.netgear.com/000045264/How-do-I-update-the-firmware-on-my-Nighthawk-Mesh-WiFi-Range-Extender
To be clear, it won't work if your device is connected to the community wifi, but it should work if you are connected to the extender wifi.
- JackalopeTXSep 20, 2018Aspirant
Of course it wouldn't work if the computer is connected to the community wifi. When the *EX7000* is connected to community wifi the mywifiext.net and mywifiext.local don't work. I have now tried both URLs on a Mac and a PC. The only way I can access settings is by doing a hard reset so that th EX7000 is not extending any network. I don't think it's a defect or a bug, I think it's a design flaw.
