BobFord
Jan 09, 2017Aspirant
EX7000 Extender & ReadyCloud
I know it is possible to use ReadyCloud for my Nighthawk Router, but is it possible to define ReadyCloud (for external access) on the extender as well?
TVMIA
Bob
- DarrenMSr. NETGEAR Moderator
Hello Bobford
You should be able to use readycloud while connected to the extender since it is still on the same network.
DarrenM
- BobFordAspirant
Thanks Darren
When I'm connected to my home network then I see the extender happily and can access the drive attached. What I'd like to do is access the extender/drive attached remotely (as I can do with my NAS and router (which also has drives attached)
Hello Bobford
Here is the list of supported routers for ready cloud access.
http://kb.netgear.com/27323/Which-NETGEAR-routers-support-ReadyCLOUD?cid=wmt_netgear_organic
DarrenM
