pukasindra
Apr 20, 2018Follower
EX7000 Extender
My Negear EX7000 wifi Extender doesn't connect to my Router since I change wifi network. I have reset it several times to factory settings to start fresh and tried conecting to my Router via WPS but...
DarrenM
Apr 23, 2018Sr. NETGEAR Moderator
When doing the factory reset make sure to hold the reset button for 10+ seconds after that try to do the manual setup of the extender instead of the WPS method. Also make sure your wireless security on your router is set to WPA2.
DarrenM
