nbor
Dec 26, 2017Follower
EX7000 fastlane
I have installed a new EX7000 estender and configured in fastlane:
I connect to the router at 5Ghz and to device at 2.5Ghz.
As result now I can see the led of 5Ghz on the extender always ON and the led of 2.5Ghz always OFF, it is that normal behaviors ?
Using WIFI analitics I can see the and connect to MY extended 2.5Ghz but I can NOT connect to the 5Ghz extended is that normal ???
The 2.5Ghz network router and extended are on the same channel is that OK ?
When I connect to the extended 2.5Ghz on my router appear that as I am connected to the 5Ghz (probabaly throu the Extender ???
Hoping in some clarifications I would like to know If I have setup all OK
1 Reply
- DarrenMSr. NETGEAR Moderator
This Kb may explain fastlane for you.
https://kb.netgear.com/24662/What-is-FastLane-Technology-and-how-do-I-configure-it
DarrenM
