Resmithn's avatar
Sep 30, 2018
EX7000 Firmware Update - GUI Language File is invalid
After clicking Yes to update, message is "GUI Language File is invalid" and returns to status screen. Email was received from Netgear
to install new update per security issues. Windows 10 environment.
We've Enhanced Your Product's Security.
Please Update to the Latest Firmware.
Your products have the following updates available:
EX7000
Download the latest firmware here
Latest firmware version: v1.0.1.78
Below are details of firmware just before attempte install.
Firmware Update
  • A New Firmware Version is Found. Do You Want to Update to the New Version Now?
  • Release Notes
  • Updated an EX7000 from an earlier firmware to 1.0.1.78 using the "one click" method on the extender, the process worked out as expected.
    The language file is integrated with the single zip archive, resp. the chk firmware image. Must be an incomplete download. Get it manually from EX7000 downloads, unpack the ZIP archive, and use the manual firmware upload from the extender Web UI.
  • schumaku's avatar
    schumaku
    • duffy79's avatar
      duffy79
      I'm having the same problem.
      I looked into doing the manual update as per the accepted solution but the release notes warn that all settings on the device may be lost. Is that likely? It makes me hesitant to follow that process.
      Is Netgear likely to fix the online update process for this soon? And is that process less likely to reset the device settings?
      • duffy79's avatar
        duffy79
        FYI for anyone interested, after no response to my query above I went ahead and performed the manual firmware update as per the instructions. It worked no problem and my device settings were retained.
