wDahl823
Sep 29, 2018Tutor
EX7000 Firmware Update Failure
Received email from Netgear about a new FIRMWARE update. Logged onto Netgear website. Clicked on message "New update is available. Click here to start." Clicked on "here" and received this message...
- Sep 29, 2018
Check out my reply to this thread. I was having the same issue and downloaded the update manually.
Red_Jester
Sep 29, 2018Tutor
wDahl823
Sep 30, 2018Tutor
Worked Perfect!!! Thanks Very Much! I really appreciate you taking time to provide me with a solution.
- Red_JesterSep 30, 2018TutorGlad to help =]
- Cris_MOct 02, 2018Guide
I updated my extender manually as well, however, I started experiencing lots of connectivity problems after the update. My devices kept on disconnecting all the time...very unstable. Had to downgrade the firmware to the previous version in order to get the extender working in a more stable fashion. Hope Netgear comes up with a fix soon.
- wDahl823Oct 02, 2018Tutor
Having the same problem (disconnecting) intermittently. Can live with it for now, hope fix is released soon.
