baR2D2thefirst
Oct 16, 2021Guide
EX7000 home page not accessible, no wifi, after reset
EX700 extender Needed a Reset, so did that with pressing the reset button. Connected the extender (latest firmware) via wifi with my router with WPS buttons. But now I do not see any wireless netwo...
- Oct 16, 2021
plemans wrote:I'm just curious if you have any other devices in the connected devices page of your router that might be the extender.
If you hardwire into the extender (with router turned off) and reboot the extener, it should get a default ip address of 192.168.1.250.
does that happen?
No other extender device shows.
I think I now understand the issue :)
Thanks for pointing out the meshing feature that I messed in the firmware update! I actually left it like that.
My network has another range than 192.168.1.x and so the reset to 192.168.1.250 will not show in my router or anywhere on my network. So I would need to set a static 192 IP on the device I want to connect. Previously I must have done the change ofhe IP from the extender.
schumaku
Oct 16, 2021Guru - Experienced User
baR2D2thefirst wrote:
Connected the extender (latest firmware) via wifi with my router with WPS buttons. But now I do not see any wireless networks from the extender, ...
This was explained before by plemans already.
...nor is the page mywifiext .net or .local accessible when I connect a laptop to the extender with ethernet cable.
This is strange, but it might depend if your host does a secure [encrypted] DNS access.
Try the IP address you see assigned to it on the router
My router shows an IP address for the extender as device READYSHARE.
Appears your router is overly smart - the EX7000 does not name itself as the host name REDYSHARE with the DHCP request. but it does annouce this name for the ReadyShare SMB disk access (in NetBIOS announcement) - that's where that name is coming from.
- baR2D2thefirstOct 16, 2021Guide
Thanks both. Still leaves me with the issue I cannot login and change settings?
- plemansOct 16, 2021Guru - Experienced User
Other than readyshare, is the IP address in your router for what IP address it has?
I cannot login to that IP, so I think not?
