pacdave
Oct 02, 2018Guide
EX7000 internet issues after firmware upgrade
I received an email to upgrade my wifi extender firmware to V1.0.1.78_1.0.140. Installation went fine. Now I cannot connect to most websites. Google I can connect to. Netgear, among many others, I sim...
- Oct 03, 2018
Yep... MANY people are having same problem .... downgrade the firmware by downloading it from netgear and applying ... looks like newest release is borked
JMW001
Oct 03, 2018Star
- yukitzOct 03, 2018Tutor
I am curious what percentage of EX7000 units updated to the latest firmware is having these issues reported here.
I figure people happy with the update wouldn't be here, so it would be tricky to determine the success rate by polling people in here.
I too had frequent disconnect issues after the update, so I rolled back to the previous version.
- JHMarOct 09, 2018Initiate
Having same issue. Changed channel...did not fix. Is there a solution that does not call for a roll back?
- JMW001Oct 09, 2018Star
Seemingly not at present. And i've found that rolling back hasn't resolved the instability ... i have effectively decommisioned my EX7000 because of this which is really annoying.
- mtapsakOct 14, 2018Aspirant
I am having problems too. Unfortunately, I'm a bit of a novice and can't figure out how to roll back to an earlier version. Is there a help thread for that? Happy for replies to [email protected] thank!!!
- StephenBOct 14, 2018Guru - Experienced User
Basic instructions are here: https://kb.netgear.com/000059563/EX7000-Firmware-Version-1-0-0-66.
On step 5, make sure you select the .chk file.
- pacdaveOct 10, 2018Guide
Thanks. I rolled it back to the previous version. No more problems.
