pacdave
Oct 02, 2018Guide
EX7000 internet issues after firmware upgrade
I received an email to upgrade my wifi extender firmware to V1.0.1.78_1.0.140. Installation went fine. Now I cannot connect to most websites. Google I can connect to. Netgear, among many others, I sim...
- Oct 03, 2018
Yep... MANY people are having same problem .... downgrade the firmware by downloading it from netgear and applying ... looks like newest release is borked
yukitz
Oct 03, 2018Tutor
I am curious what percentage of EX7000 units updated to the latest firmware is having these issues reported here.
I figure people happy with the update wouldn't be here, so it would be tricky to determine the success rate by polling people in here.
I too had frequent disconnect issues after the update, so I rolled back to the previous version.
JHMar
Oct 09, 2018Initiate
Having same issue. Changed channel...did not fix. Is there a solution that does not call for a roll back?
- JMW001Oct 09, 2018Star
Seemingly not at present. And i've found that rolling back hasn't resolved the instability ... i have effectively decommisioned my EX7000 because of this which is really annoying.
- StephenBOct 09, 2018Guru - Experienced User
You might try one more factory reset of the extender, and reconfigure. When the format of the settings file changes, they convert it when upgrading, but they can't back-convert it when downgrading. So you can end up with some bogus settings (not always visible in the UI).
- schumakuOct 09, 2018Guru - Experienced User
Didn't work for us at all. Spent hours for updating and reconfig. Then we discovered the EX7000 in AP did not even pick up an address by DHCP on the wired GbE anymore, it "disappeared" - and the users complained about the loss of Internet connectivity.
- pacdaveOct 10, 2018Guide
I had to foll my firmware back to the previous versions. Easy to do. No more problems.
- danielgeorge000Oct 14, 2018Initiate
None that I know of. See my comments (#24 in this thread)
- drewtabsOct 16, 2018Aspirant
have had same problem, update is buggy, been on with tech support for 3 hours, still no resolution
