BudDieselman
Nov 18, 2018Aspirant
EX7000 iOS connectivity issues
I've researched and read posts of other EX7000 and iOS users having the same issue. I have uploaded older firmware versions and still have limited connectivity with my iOS devices. I am able to conne...
Bendeego
Jan 31, 2019Guide
I have had the same issue ,on my EX7000. I could not connect my Ipad to the 2.4 ghz channel ,nor could I connect my smart tv to the extender either,
i solved the problem by changing the security settings to WPA-PSK Tkip Wpa2 Psk AES ,,
i have a EX6200 that had the same trouble and this changed fixed that also,
this problem arose after upgrading both units to latest level of firmware,,
hope this helps
Regards
Peter H
- BudDieselmanJan 31, 2019AspirantThis worked! Thank you!
