ArcherX
Jan 08, 2017Initiate
EX7000 Nighthawk AC1900 Range Extender 5 ghz connection issues
I'm having issues with my 5 ghz on my new WIFI extender. My 2.4 ghz extention works most of the time but will occasionally just boot me off. My 5 ghz, while it flashes green on the LED indicator pa...
ArcherX
Jan 11, 2017Initiate
Darren,
I am currently using a Technicolor TC8717T, also since my last post the 2.4 ghz has continued to go out with more noticable frequency.
archer
DarrenM
Jan 12, 2017Sr. NETGEAR Moderator
Hello ArcherX
You could try a couple things. Make sure your EX7000 is on the latest firmware. You could also try to adjust the wireless channels on your main router maybe some other wifi network or home appliance is causing the drops in the signal. Last thing is you could try to factory reset the extender and set it up again.
DarrenM
