danpingel
Jan 16, 2017Follower
EX7000 Nighthawk WiFi Range Extender doesn't play well with AT&T U-Verse
Hi, I recently purchased the Nighthawk WiFi Range Extender to boost the WiFi in my house. I have AT&T U-Verse and the wireless network provided by their residential gateway (ARRIS NVG589), but it...
TheEther
Jan 16, 2017Guru
A wired access point will always be superior to a range extender with respect to reliability and speed, so I would go for that if at all possible. You can leave the Wi-Fi enabled on the NVG589 in case you need it in the basement. Just make sure to use a different Wi-Fi channel.
Otherwise, try moving the EX7000 closer to the NVG589.
