DrCharlesForbin
Apr 17, 2017Apprentice
EX7000 no internet connection
Ok - I'm stumped on this one and I'm not paying $50 for a support call if I cana get a new one for $100. Recently, my EX7000 (in Access Point mode) has been reporting that it has no internet connect...
DrCharlesForbin
Thanks for responding. I'm sure they're unrelated, just strangely coincidental. WPS works fine - I have my wifi printer working through it. I'm probably going to wind up doing a hard setup on the TiVo adapter from my laptop.I bought a new TiVo and moved the old one from my family room to my master BR.. but my BR doesn't have a hard wired Ethernet connection. The older TiVo that was there before worked fine with the TiVo that was there before. Aldo factory reset the Tivo adapter. WPS says it's syncing but the indicator on the adaper says it's still searching. Just a giant pain when things don't work the way that they should. This is not brain surgery.
- DrCharlesForbinApr 17, 2017Apprentice
Just FYI - Tivo adapter was fine - bad patch cable to the TiVo... looking at the back of the box after testing the adapter - no lights. Still doesnt solve this problem.
